400V Supply on 380V motor
will there be any long time effect if we connect 380V 60Hz motor to 400V 60Hz supply?
Thank you.
Thank you.
RE: 400V Supply on 380V motor
Where do you have 400 V, 60 Hz by the way ?
Muthu
www.edison.co.in
Are those effects will still happen even if the motor has 5% voltage tolerance?
