Gas station Canopy Footing
The gas station canopy is 102'x30' and supported by 4 HSS columns. I am designing only the footing and making sure it is sized for a moment as well as axial load provided by canopy manufacturer. Below the canopy is a slab on grade. The bottom of each of the four footings will be 4'-0" below the finished grade. There is also a slab on grade for cars and trucks to drive up to fill up. Do I need to take into consideration any impact for loads from these vehicles onto my column footings?
RE: Gas station Canopy Footing
Yes.
No.
Definitely no.
Mike McCann
MMC Engineering
Motto:  KISS
Motivation:  Don't ask
If the bottom of the footing was only at 2 feet down, I would say yes, but not at 4 feet.  Any impact force will be too dissipated at that depth to worry about.
Mike McCann
MMC Engineering
Motto:  KISS
frv - Can you please elaborate?
question is a little unclear - do you really mean "impact loads" as in dynamic loading, or do you mean "impact from"  static or slow moving vehicle live loads?
The latter cvg.  Moving vehicle impact loading - at 10 mph or less.
Mike McCann
MMC Engineering
Motto:  KISS
The latter is the correct answer.  When cars/trucks pull up to fill up its usually slow speed.  Or worst case when the oil tanker drives by to fill up the underground tank.  Do I need to include the load of these vehicle on the footings for these columns that support the canopy?
I would use a vehicle surcharge of 50 psf for passenger cars and trucks.
Mike McCann
MMC Engineering
Motto:  KISS
For vertical loading on the column footing, you should consider a surcharge load.
Any impact load from a vehicle actually running into the column is usually not a problem as curved bollards are usually installed around the gas pumps and columns.
Also, be careful to include the surcharge in proper combinations as it can both help/hurt your overturning calc's.
Sorry if I am stating the obvious.
Not sure if it would be relevant in this case but if you were to check the foundations presumably with the slab cast around them you may be able to distribute any lateral load over several foundations.
ToadJones is correct about curved bollards protecting gas pumps.  I know--my 18 year old daughter drove her older sister's car into one a few weeks ago.
I have spent the last couple of weekends doing auto body repair work curse
DaveAtkins
Dave-
Better than hitting the gas pump!!!
Funny picture!
Not funny for the owner of the SUV, of course.
DaveAtkins
No.  Provide separate bollards for pump/column protection.
Why wouldn't you design it for the impact of a vehicle?
It really isn't that stringent. I don't have the IBC in front of me, but it's something like 2 or 3 kips at 2'-3' above finished grade.
This loading is intended to account for a vehicle accidentally backing into it. And this is certainly a possibility.
Now, if you have the bollards as others have suggested, then you wouldn't need to design for the impact, as the bollards would absorb this.
I think the issue is being confused here....I do believe the OP was worried about surcharge on the footing, NOT inmpact on the column. This might be semantics.
TJ...you might be right...I didn't read it that way, but makes sense.  In any case, the traffic loading is likely not going to be directly over the footings and most would be dissipated by the slab and the distance between them.  In short, I would not consider a traffic load on the footing, either.
Thanks guys!  I am only designing the 4 footings. The columns and superstructure are designed by the canopy manufacturer who didn't take into account an impact load but the columns are HSS 15x6 or something big like that.  My area of expertise is buildings not these small structures and my experience says those columns are good.  As for spread foundation, I think I will take into account an addition 50 psf.  My footing is already large due to moment so I don't think I will need to resize it by much more.  I really appreciate your input.  This is my first time posting here.  And I am impressed.  I don't usually get this much feedback even at work.
Although you didn't ask about it, remember to check against wind uplift.
LonnieP
as I alluded to before, and Lonnie has pointed out, do not include surcharge in all cases, such as uplift.
Again, I am probably just stating the obvious.
wind uplift - check
traffic surcharge to check for downward pressure - check
Thanks so much for all your input.
love this forum.
nadia
Regardless of whether the columns are protected by bollards, I would design the footing only for gravity loads from the roof and wind uplift loading.  Traffic surcharge and impact would be incidental and would have little effect on a footing founded 4' below the surface.  If the footing were at a higher level, I might consider the impact as a momentary overturning moment.  But if something hit a column hard enough to displace the footing, the whole thing would have to be rebuilt anyway.
Oh, and of course there is lateral load from the wind also, the moment from which would doubtless exceed the impact moment.
hokie66...exactly
That's a good point, hokie..
I guess it's just a check I've been accustomed to do whenever I have anything exposed to vehicular impact..  but I think you're right..  In this particular case, it's quite obvious by observation that wind loading would control both overturning moment and probably shear on the footing..
So on second thought, I change my answer to "No."
