.odb section deletion
I have a simulation model consisting of several layers which are divided into sections. In the odb.-file, I´d like to
chose some of the sections and save them into a new odb-file.
My problem is, that a fieldOutput that I implemented has values for the layers that are too different to each other and the Abaqus-postprocessing does not generate a reasonable contour-plot. So I need to totally separate the layers.
Is it possible to delete parts of the model from the odb-file?
I haven t found a possibility, neither in the GUI, nor in the Scripting Manual.
Thanks for your help,
Maddog
Maddog
