Dissolving equation
Dissolving equation
first of all: Sorry for my bad english. I hope you can understand my topic.
In MathCAD I want to solve a relatively complex equation with at least two unknowns.
The equation has got the following style: x + y + a = b, with a and b as constants.
Now I want to dissolve to x or y. After command "...solve,x -> q" MathCAD notices "No Solution found". I think the equation is too complex.
So is there any other possibility to compute x or y after defining one of them?
Here the link to the equation: http: //www.bild er-space.d e/bilder/b cab74-1278 433362.jpg
Thanks for help.
so long...
Thanks for help.
so long...
RE: Dissolving equation
TTFN
Which solver should I use better?
I don`t need the solved equation necessarily. I need to know the solution of one of the variables depending on the equation by defining the other variable on my own.
TTFN
Peter Nachtwey
Delta Computer Systems
http://www.deltamotion.com
