Assembly to a Part
Assembly to a Part
Is there a way to save a Solid Edge assembly to a part?
RE: Assembly to a Part
Whether its successful will depend on the assembly.
Some conditions such as an edge lying on a face may cause an error.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
Please note, I've done the technique beachcomber mentions, we once asked Solid Edge about it and they strongly discouraged us from doing it.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
thanks
To be able to create a part file of the assembly, the methods described in prior posts are the only solutions. You could modify your assembly to eliminate the possibility of the non-manifold conditions, but you have to just look to find them as there are no analysis tools to help you.
Ken G.
http://grundey.blogspot.com
You talk about saving parts from the assembly to re-use later.
Could you explain?
bc.
Quadro FX4600.
thanks
This has little or nothing to do with the OP by the sounds of it, I suggest a new thread.
I can't think why you would have the impression that you would need to.
If you can explain a little more exactly how you are building your assembly it might help us to help you.
bc.
Quadro FX4600.
