Fuel Pressure Increase
I have a Natural gas fueling system and I need to boost the pressure of the NG from 50 psi at the tank to 100 to 150 psi for delivery and consistent pressure at the engine. any suggestions?
RE: Fuel Pressure Increase
Use a compressor.
Cool the gas a lot before you pump it.
Make sure the container will withstand the maximum pressure you will reach after a heat soak on a hot day with a very good safety factor as a rupture will be quite spectacular.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
I wish to pump CNG to 150psi
Can anyone recomend a source of a pump you might get a response from someone who does instead of us both wasting the time I put into this.
I don't know a source.
Have you tried google
Pat
for site rules
