Patran 2010 Graphic problem Help!
Hi, All members
I have a problem with my patran 2010 -skin
When I could not maximize the window program or use such a scrollbar
Could anybody guide me how to solve these problem?
Thank for advance
John
RE: Patran 2010 Graphic problem Help!
Check my temporary patch under windows 7
quote:
Well, Patran 2010 Skin GUI Under Windows 7 x64 Temporary fixed.
@bodrillone
I've found out that there are a few issues on the interaction of Patran and windows 7 while accessing the register...
You can try running the classic GUI and extend the size of the image... then close it and run the skin GUI.. check the difference.. :)
Run my temporary fix and it will do it for you right on the register. And is temporary because if you resize the window you will get the same issue again. just close patran and run the .vbs file
Download link:
http://rapidshare.com/files/437951319/Patran_x64_Skin_Win7_fix.rar
Feel free to let me know if also working for you..
Damn ... scroll bars still don´t work
Hello everyone
I am trying to install Nastran & Patran, but for some reason i can only use one at a time and not both at the same time since they use the same Flexlm configuration utility... so every time i have to run the config remove the licence and put the one i want to use..headache .... would greatly appreciate if anyone have any clues
@bodrillone
I've just discovered that if you turn of windows 7 UAC, patran will run better under -skin mode... this way my patch is not necessary... although scroll bars still not working, it got better.
@wonder1
just add the nastran license file (.dat) features to the patran license file... try doing it in alphabetical order...
you can also create a new license service at a different port for one of those...
