Mass Flowmeter
Mass Flowmeter
Any comments / help on selecting the best flowmeter that will be reliable in measuring the flue gas in a duct (15' x 15').
I am leaning towards the selection of the OFS-2000 (Optical Scintillation)and would like to get any feedback on it.
Thank you.
Yasmina
Thank you.
Yasmina
RE: Mass Flowmeter
However, you should talk to these people. I built a mass flow meter\computer for them, years ago, that was for the stacks of the second largest gas fired power plant on the planet. So I know they do this large stuff. That was a special one as it was a sampling totalizator system for determining the particulates leaving the facility.
http://www.kurz-instruments.com
BTW: I have no association with Kurz at the present.
Keith Cress
RE: Mass Flowmeter
I know the Sierra mass flowmeter and use it in more aplications and work fine.
best regards.
RE: Mass Flowmeter
Sierra would be affected by temp, moisture and any variation in the composition of the gas. I am more thinking of the optical as it is virtually unaffected by such variation as lon as the temp is not < 100F. Any references on the optical.
Thx all.
