heating by water pipes
I want to heat an industrial heavy insulated building by installing 750 mts of water pipe under or in the 100mm concrete slab. The intention is to use a solid fuel stove to heat this water, and a pump to circulate it.
I would be grateful for any tips on type of economic piping, probable efficiency of this system and likely temperature rise.
Thanks, kenguy
Thanks, kenguy
RE: heating by water pipes
http://
htt
John Seigenthaler does seminars.
http://www.healthyheating.com/Siggy/Siggy.htm
