How to make boundary curves from mesh objects?
Hi everybody,
I need to find an easy way to make a boundary or a silhouette curve of STL/mesh bodies.
I use that curve as a limit for machining.
Actually I make an sketch using splines and afterwards I offset that curve and extrude it to generate de machining stock, but this costs me lot of time.
I've tried to make it automatically using "Insert->Curve from bodies->Extract Curves->Shadow OutLine" but it always asks me to set the "Hide Invisible Lines" view, even when is activated.
Any idea?
Dani.
