Is it possible to make Draft Analysis on mesh bodies in NX6.0?
Hi all,
I have to machine several STL mesh bodies. In order to avoid as much negatives as possible it would be great to make a Draft Analysis, but I can find the way.
When I try to use "Analysis ->Shape->Draft" the STL objects are displayed as normal and I can't see any negative angles.
Is there another way?
By the way, I can't make reverse engineering of that objects due its complexity.
Thanks in advance,
Dani.
Thanks in advance,
Dani.
