utility connector question on P&ID
Fig1 .Pump discharge fluid is acetic acid . and utility connection is nitrogen/service water.
Fig2. The process line is nonyl phenol exthoxylate and utility connection is nitrogen/service water.
(Please see attached file)
My question is why the utility connection in fig 1 have no spectacle blind like figure 2.
I know that there may be the two reasons to put spectacle blind (1). The process line is easy to leak or highly Explosive / (2) The process is batch not continuous.(3) higher design pressure
But this seems not fit the above requirement. Please help me out.
Thank you very much.
RE: utility connector question on P&ID
Check valves are not effective.
Hose connectors with plug are easily available.
I can't think of a reason to blind figure2 other than odor prevention.
Hope this helps.
Onwards,
Matt
