Pipe head loss - Cameron Hydraulic Data inaccurate?
Has anyone had any experience using Cameron Hydraulic Data for their head loss calculations? I was recently checking some head loss calculations when I discovered that the head loss I had calculated was almost double of what was previously done. Doing some backchecking we found some discrepancies between what Cameron uses for head loss and what other sources use. For example, for a 16" CHW Sch. 40 steel pipe at 6,000 GPM, Cameron has a head loss of 9.31'/100'. ASHRAE has the head loss at around 2'/100'. I checked other sources (Bell & Gossett/Carrier/etc) and they all agree with ASHRAE's estimate.
Can anyone explain such a large discrepancy, or has any experience with large differences between Cameron and other sources?
RE: Pipe head loss - Cameron Hydraulic Data inaccurate?
Have you tried the Crane 410 method ?
This is the methodology in most common usage....as i understand
I have tried the Crane 410 method, and it gives similar results to ASHRAE. My question is why is Cameron giving head loss estimates that are seemingly so out of line with the rest of the industry?
There's a double line down the middle of the page dividing the two categories.
"We have a leadership style that is too directive and doesn't listen sufficiently well. The top of the organisation doesn't listen sufficiently to what the bottom is saying." Tony Hayward CEO BP
http://www.youtube.com/watch?v=hpiIWMWWVco
"Being GREEN isn't easy." Kermit
http://virtualpipeline.spaces.liv
rmw
