Hose for Lime slurry
Please guide me what material and type of hose is suitable for Lime slurry application with 90 Deg C temp and with 160 PSI pressure. My specification further says 3:1 refers RMA standards
Please help!
RE: Hose for Lime slurry
Depending upon the hose size and length I would not see any problem in using a standard rubber hydraulic hose with steel reinforcement. They are cheap for small sizes and you will get them everywhere. And their pressure rating exceeds your requirement by far.
Hi Micalbrch, Thanks for the headsup...
Do you suggest me any specific references so I can keep a basis for my selection ..thanks in advance!
Not really a reference if you mean a standard. But check www.parker.com. I think you get some good help from there. And they have offices worldwide.
