ANSI Valve standards
I need info in ANSI  valve wall thickness requirements....ie. how thick should  a 300# ansi  ball valve of 10" size be???
anyone know how to access the ANSI codes online?
RE: ANSI Valve standards
Any valve sold under that classification would have to meet the standard.
To attain the ANSI Standard you would have to go to their website and order a copy of the standard.
If you are worried that a valve has worn out after being in use, it would be best have the manufacturer evaluate it for repair.
