Curves disappearing when Background is ON in Section View
Hola!
Any ideas why I'm losing lines when I enable Background in a section view? The images uploaded display a finished part (hidden lines) within an in-process part.
RE: Curves disappearing when Background is ON in Section View
What version? And can you post the part or some similar cases in point?
Try decreasing tolerances under the general tab perhaps!
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
It's ver. 7.0.0.9. We should be getting 7.5 installed this week. Unfortunately at this stage I'm not permitted to supply the file; so far this is the only file behaving like this.
I had played around with the adjacency tolerances from .050 to .0005 with no difference.
Also try larger tolerance values, seems strange but sometimes increasing the tolerance has a positive effect.
I can only give you a guess on this one.
If there is a way to put the curves (that are disappearing)on the same plane as the section curves then your problem should be solved - but if I understand this view correctly it doesn't look like that would be an easy task here.
In drating try right clicking on the view, selecting style, then click the hiddenlines tab, try experimenting ticking some of the options on this tab like self hidden and interfereing solids etc and see if this helps. Just a guess mind without actually seeing the model. smile
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX6.0.3.6 MP2 native)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
I've tried everything suggested, but to no avail.
Thanks anyways.
Also try doing a geometry check on your part. If you turn up any consistency or self intersection errors on your model, the drawing may behave strangely.
just another guess:
view style > general > extracted edges > toggle between "associative" and "none"
My bad. I missed JCBCad's suggestion.
In View Styles, the Hidden Lines tab, setting Interfering Solids from "None" to "Yes, Without Inteference Curves" seems work.
Thanks!
