Rendering Clear Plastic
Can anyone suggest a good place to start when rendering clear plastic? I need to generate a very realistic image of a product, but everything I try in Photoworks looks very bad. For the material, do I use Polycarbonate, Polypropylene, Glass? I need a white background, but don't know if I can start with some other scene and change it. Also, what about lighting? Any suggestions would be greatly appreciated
RE: Rendering Clear Plastic
Look at using Photoview 360 and go to luxology.com to download glass Environments and materials, might help with your Clear plastic problem.
Scott Baugh, CSWP pc2
Berry Plastics
Cad Admin\Design Engineer
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
Forgot to clarify, it appears perfect in Photoworks and Photoview as well.
If you don't find that good enough and decide to go one step further, you may want to look at "Blender" (www.blender.org), especially if your not disgusted to use open source applications (free software)
I've had good luck using Clear Thick Glass in PV360 as a stand-in for clear plastics.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
Fine.  I'll ask the question:  what do you mean when you say it looks bad?  Can you post a bad pic?  It could just be your lighting or it could be something else.  We're all just guessing otherwise.
Dan
www.eltronresearch.com
Dan's Blog
