Format Visibility
Format Visibility
i have a prt file from a customer that has a format (titleblock). it is visible in the preview but when i open the file parts of the title block are not visible. the customer tells me to check the layers because the format is on layer 9. i have checked it and it is selectable. the drawing was created in nx4 and i am opening it in nx 6. any help would be greatly appreciated. thank you in advance.
RE: Format Visibility
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
i see the layer visible in view tab , but i don't see an option to add.
i see the layer settings tab, but i don't see the make visible in view option.
i apologize for the newbieness.
Thank you
"Format --> Visible In View --> (pick drawing view) --> OK --> click layer 9 --> visible --> ok"
No effect.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
where "Directory of Pattern Files" is the place where you need to place the pattern files, so that ug loads the pattern formats from this directory only.
For example,
UGII_PATDIR = M:\Standards\Patternfiles
