Default .pdf location and naming
I would like export .pdf to behave like exporting parasolids (and most everything else) in regards to the naming and location of the file. This is totally a user error complaint, but I am forever accidentally overwriting the last pdf as that is the default name for the new pdf file instead of using the name/location of the part file the .pdf is being exported from (like parasolids, steps, images and most everything else does).
Is there a setting somewhere where this can be corrected?
Once we get Teamcenter setup correctly this will be less of an issue, but I'd like to fix it regardless (if possible).
KLINE
RE: Default .pdf location and naming
Just want to add a voice to this request.  It's a bit of an annoyance to have to manually rename the desired pdf, when usually you might want the pdf to basically take the same name as the part file.
Awesome. Works fantastically! Sorry I missed that thread earlier...
Have a Great Weekend!
KLINE
