Phase Failure Test
Phase Failure Test
I'm looking for a way to catch phase failures from the connections welding shut. My initial thought was to test all three phases for current after the connections were opened. If I still had current flow in any phase, then I would know if there was a weld. I was told that this would only work if at least two of the phases stayed shut. I was wondering if this is in fact true.
Thank you
Thank you
RE: Phase Failure Test
Gunnar Englund
www.gke.org
