Bolt Grade confusion
We regularly use A320 L7 Bolts in our work for load bearing connections, but am I right in saying that standard 8.8 bolts aren't actually that far off L7 bolts in terms of strength and 10.9 or 12.9 are actually stronger?
Thanks.
Thanks.
RE: Bolt Grade confusion
Hi mechmos
Look at these sites and you can compare the grades:-
h
http:/
desertfox
