solid edge
solid edge
solid edge
can i open unigraphics files in solid edge environment.I mean if a design a part in unigraphics can i opne that part in solid edge.
RE: solid edge
  yes  u  can  certainly open  unigraphics part  in  solid  edge .  parts can  be  opened  directly or  through   parasolid  translator .  try  it  &  good  luck .
RE: solid edge
As well as being able to open the UG file in Solid Edge, you can also maintain associativity if they are on the same network, i.e. you make a change to the UG part and the part updates in SE.
