Assembly Constraints and Arrangements
Is it possible to have arrangements work through expressions, suppression by expression, or by loaded feature? Automating wise, it seems that assembly constraints are limited.
You can create a mass of components and constraints and the components currently active will display the constraints as being on, but all of the other ones will display as being failed. I was wanting to suppress constraints by expression, but that does not appear to be possibly in nx 6.
As for arrangements, if you have an assembly with sub-assemblies, not all are visible at the same time, you are forced to have all of your constraints at the top level? Maybe someone can enlighten me.
Assembly
Constraints
Component
Component (suppressed by expression)
You will have all visible constraints, including the failing ones. I would like to have it suppress the constraints or select an arrangement automatically, depending on what features are suppressed/unsuppressed.
Thanks in advance.
Assembly
Constraints
Component
Thanks in advance.
RE: Assembly Constraints and Arrangements
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
