Slow Environments - PV 360
Has anyone seen the environments take about a minute to come up when using PV 360 2010 SP3?
Mine has to keep searching for the Environments, I didn't find anything at the Knowledge base.
Scott Baugh, CSWP ![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
FAQ731-376: Eng-Tips.com Forum PoliciesQuote:
"If it's not broke, Don't fix it!"
RE: Slow Environments - PV 360
Does PV360 SP3 get installed with SW SP4?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
Dan
www.eltronresearch.com
Dan's Blog
Right now I just keep the Environments up all the time and just drag it low in the screen.
I have seen this before, but the solution then was to reinstall and as you know with an Admin image that can be a bit of a pain.
Mr. Mango - in regards to your question I am not following you... sorry if I am missing it... new job is already keeping me up late at night working, so I am a bit tired today.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum PoliciesBerry Plastics
Cad Admin\Design Engineer
www.scottjbaugh.com
Is this on your home machine with the non-approved graphics card?
www.scottjbaugh.com
Rob Rodriguez CSWP
www.axiscadsolutions.com
www.robrodriguez.com
http://www.robrodriguezblog.com
Eastern Region SWUGN Representative www.swugn.org www.nvtswug.com
SW 2007 SP 2.0
