Fuel density change with temperature formulae
Can anybody provide me with an equation to calculate the fuel density change with temperature. Also any official references
We measure fuel flow rate with a turbine flow meter and need to have the flow rate in pounds per hour.
Knowing the density we can simply multiple the volumetric flow rate (gph) by the density (lb/gal) to get the mass.
Suppose we measure a fuel sample density and temperature.
Then we flow the fuel and dynamically measure the temperature.
What is the equation to calculate the new density due to the temperature difference.
The fuel is Jet A-1 (JP-8) aviation fuel.
Any advice gratefully received...
RE: Fuel density change with temperature formulae
Jet fuel
http://www
Bulk Modulus
http://w
"We have a leadership style that is too directive and doesn't listen sufficiently well. The top of the organisation doesn't listen sufficiently to what the bottom is saying." Tony Hayward CEO BP
http://www.youtube.com/watch?v=hpiIWMWWVco
"Being GREEN isn't easy." Kermit
http://virtualpipeline.spaces.liv
These days the recommendation is that the calculations are the standard and not the tables.
There is a spreadsheet solution here:
http://viscoanalyser.com/page8.html (Density 12MF.xls) which has been independently checked but which doesn't yet have the pressure correction. In your case, if you know the volume at standard conditions (Turbine meters are velocity meters and so usually have factors to correct for temperature and pressure geometry effects.)then you want the density at standard conditions.
Of course, if you have a turbine flow meter, you could simply add an online density meter. Engine test rigs have often chosen the turbine meter and density sensor path to mass flow over coriolis meters because of the much better response of the turbine meter to step changes in flow (Typical figures quoted are 7ms to a 90% of a step change in flow). Not sure about modern coriolis meter response times so it may have changed.
JMW
www.ViscoAnalyser.com
I still need the actual formulae, which I'm trying to track down.
I had a forumla from Honeywell performance department years ago but that needed the SG of the fuel at 60 degrees F. So I would have to calculate that? then compensate for the live fuel temperature reading.
JMW - A live density meter might be the way to go in the future but my presnt project doesn't have one, so I need to calculate it all...
Note that when you are calculating the density at 15oC it is an iterative calculation.
http:
These calculations are not strictly as per the Manual of Petroleum Measurement Standards but the results check out fine.
Be careful if you go after the pressure correction because these manuals repeat the information twice and there is a difference.
JMW
1020 is the gas and as I just discovered, whoever set up this new web page has linked the same gas manual to the first three links.
The fourth link is good.
JMW
