Rapid Accelerator
Rapid Accelerator
I have Matlab code that runs a simulation. It works fine in Normal mode and Accelerator mode. But when I run that same code with the model in Rapid Accelerator mode, I get the error:
??? CAT arguments dimensions are not consistent.
The data import/export is set to read time and input variables [t,u] from the workspace and to export the variables tout, xout, and yout to the workspace.
The command I'm using is
[tout, xout, yout] = sim (sys);
As I said, it works in all but Rapid Accelerator mode. When I change the command to
[tout, xout] = sim (sys);
It works, but then I cannot access the outputs, which is really what I'm after in the first place. Any thoughts?
Danny
Danny
RE: Rapid Accelerator
may help
Cheers
Greg Locock
