Two teeth in contact
Hi All,
Urgently it is necessary (working) example (input deck) of two teeth (spur gears) in contact (under some torque). Please help.
Many thanks in advance.
Mike
Mike
RE: Two teeth in contact
Thanks for your message.
I knew about this model, but it simulates the mechanism. My problem is about contact and stress under contact.
Mike
Thanks for the message. I need inp-file as an example of two gear teeth in contact under some torque.
Mike
