Change Text Box decimals
Could someone tell me how to change the number of decimals to use on mathcad´s control textbox, when I am using a input variable. Maybe using Edit Script? Thanks.
Sergio
RE: Change Text Box decimals
CODE
Sub TextBoxEvent_Start()
  Rem TODO: Add your code here
End Sub
Sub TextBoxEvent_Exec(Inputs,Outputs)
    Value = CDbl(TextBox.Text)
    IntVal = Int(Value)
    Str = Len(IntVal)
    Txt = Left(TextBox.Text,Str+3)
    Outputs(0).Value = CDbl(Txt)
End Sub
Sub TextBoxEvent_Stop()
End Sub
I think, this is what you want. Of course, you'll have to change the "+3" to something else. This gives you only two digits after the decimal point.
