304 sTAINLESS VS. 18/8
We are having a discussion over whether 304 stainless and 18/8 are the same material.  My arguement is that 18/8 is the "family" and 304 is a member of the family along with 304L, 304H, 302...
basically, 304 stainless is an 18/8 steel, but 18/8 is not 304.
I am not a material specialist, so please bear with my lack of knowledge.  Can someone set me straight?
RE: 304 sTAINLESS VS. 18/8
nmiltner;
Normally, grades of stainless steel are identified by number prefix 2,3,4xx. The "18/8" means nothing other than a generic classification. In reality, ordering a particular grade of stainless steel should be by UNS.
You are correct in your statements.  18/8 is still used by component suppliers as a materials designation for Type 304 sst.  But as you state, 18/8 can fit more than just Type 304, so buyer beware if corrosion resistance or other special properties are required.
Am I wrong in thinking that the Nickel content of a 304 is higher than 18/8? In my experience, 18/8, 17/4, 15/5 etc refers to chromium/nickel. Since 304 typically has at least 10% nickel, wouldn't this make it more of an 18/10?
Yes. 304 has 8.0% minimum nickel. It is allowed to have up to 10.4 but you get more only if you specifically pay for the expensive extra amount. 18/8 is merely a nickname for 304. It was also the nickname for the outdated 302. Europeans started calling it 18/10, still a nickname, when they also knew it seldom, if ever, had that much nickel.
Michael McGuire
http://stainlesssteelforengineers.blogspot.com/
