Professional looking 3D layout
Hi guys, this is my first post here.
I have a question for you. I need to do a layout of one of our products for a presentation. I don't want to use a render for this. I want something that looks similar to the attached image.
Do you guys have any idea how I could achieve that (with solidworks or photoshop or any other program I may need:P)?
RE: Professional looking 3D layout
Creating Layers (in the drawing) with pre-assigned line properties will help.
It looks like you have two separate assemblies there.
You can output each from SolidWorks to a JPEG file, then process the JPEGs using Adobe Photoshop, or the GIMP. With SolidWorks images, I could definitely do your graphic with the GIMP.
As shown, your two chairs overlap. Perhaps this is not absolutely necessary. Attach each drawing view from separate models. Use layers to manipulate the line weights and colours on one or both views. You can manipulate line weights and colours by clicking on the individual lines, but this is a lot more work.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Thanks a lot
