hoop stress
hoop stress
How can I simulate the stress created by a hose clamp on a plastic body,the kind where a radiator hose fits over a barb on the plastic body and gets clamped? I have never done anything like this in Mechanica.
RE: hoop stress
I would create a contact inteference model. If the hose or plastic part that you are clamping to has a load-deformation response consistent with hyperelasticity then you would need to set the hyperelastic material model on the hose/plastic part.
If the part is sufficiently long you could also use a 2D plain strain model for the simulation.
There really are a multitude of ways to attack this sort of problem.
Good luck,
Steve
Stephen Seymour, PE
Seymour Engineering & Consulting Group
www.seymourecg.com
