question about kinematic coupling
Hi , i have a problem with a simple connection, and when i am applying a moment on a surface on this connection, this plate is not moving as i am expecting, it just moves in one direction and all the places of the plate to the same direction, i guess it has some relationship with the kinematic couplin, i have change the constrains but it is not working, can someone help me with this?
i am attaching the file, thanks a lot if someone can helps me
tatika
tatika
RE: question about kinematic coupling
Rob Stupplebeen
I would apreciate if you can help me with this it would be great. my problem is the way how this is moving and having deformations, i think it is because of the kinematic coupling, but if you know any other reason it would be fantastic. Thanks a lot
Tatika
Rob Stupplebeen
