Involute gear cutter sizes
Good day:
I am trying to learn how to cut gears and am finding very little information to go on. For example I have come to realize that each involute gear cutter is more or less for one specific task. I have also learned that they are either Module or DP and that they are in reverse order Module designated from small to large and DP from large to small. The only thing I have not been able to find is a comparison chart showing each size and what gear diameter it will cut. For example I would like to start of by cutting a few small 1.5 to 2 inch gears and am at a loss of which size cutter to buy. I would really appreciate any information you guys could share, including any books, website you could recommend for novice such as myself. Thanks in advance for your time an effort in helping me . Henry
RE: Involute gear cutter sizes
discuss your issues with your cutter suppliers.
depending where you are located. they will help you.
in the USA, Gleason Cutting Tools are good. Ash Gear
Barit International is an other. many others too.
Gear cutting tools is their specialty.
each gear must be calculated to verify that the cutter
will work, there are so many variables.
for instance the AGMA or ISO quality of gear required, the quality of the cutter.
is the D+F of cutter correct for the whole depth of the gear. Tooth Thickness to root diameter correct.
is it pre-grind or finishing.
if in the USA contact Ash Gear, have them send you their catalog It has a wealth of information.
There is more too.
HTH
MfgEngGear
