Capture3D to Solidworks: Creating surface from 3-axis integration mesh
Hi all,
I have a 3-axis IGES file that was converted from raw sections taken from a 3D optical scanner.
While I've found how to merge all three axes in one drawing, I'm finding it very difficult to create a surface using these mesh points.
Can anyone help me out?
Mark
RE: Capture3D to Solidworks: Creating surface from 3-axis integration mesh
Some versions of SW have something called "Scan to 3D", which allows you to convert a pointcloud to a surface.
If it can patch surface defect in the scanned data i don't know. Maybe this functionality in SW is too limited for serious use, i don't know, never heard much about it for some reason.
Check out youtube "scan to 3D solidworks".
That's you're only option with SW.
