Outdoor 27.6 kV Bushing CT
COuld you advise the preference for a porcelain type or epoxy material for bushing CT application for a 27.6 kV outdoor installation. I tried to search a lot but not much help.
I would appreciate a word.
RE: Outdoor 27.6 kV Bushing CT
Look at the failure modes, you'll find epoxy much friendlier.
Thanks David.I  have tried to find literature but not much help. I have not been long enough in industry to experience failures and success of these bushings. I can only rely on industry trend, literature and opinion of people like your self.
Let me rephrase my question:
 Which of these two choices would be a industry trend ?
Your response tells me Epoxy.Then why porcelain is still in lime light?
I would appreciate your input.
Maybe I don't follow your question, but a bushing CT doesn't have an insulator. Bushing CTs go around bushings or inside transformers around bushing transitions.
If you're asking about a 25 kV class post-type CT (i.e. not a bushing CT), dry-type CTs dominate that voltage class, primarily based on price advantage over oil-filled units, size, weight, mounting flexibility, safety, etc...
