Export jt file from TeamCenter
each time I save an assembly or a part, NX generates a jt file that is saved inside the Item_Revision.
It's possible export this jt outside to TC ?
Thank you...
Using NX7.0 and TC8.1
RE: Export jt file from TeamCenter
Best regards,
Michäël.
NX4.0.4.2 MP10 / TCE 9.1.3.8_build_0711 / NX6.0.2.8 / NX7.0.0.9
Belgium
are you talking about procedure from NX or from TC ?
I don't want load the assembly to export.
I would like to export from TeamCenter.
Thank you...
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX6.0.3.6 MP2 native)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
your solution works fine.
Thank you.
Thank you...
