ANSYS- Deformed Shape Model Processing.
I wonder if it is possible to export the meshed deformed shape resulted from a static analysis (i.e. a displacement analysis) so it can be:
- first used to proceed some geometry processing (for instance remove from this deform geometry a sphere of center C=(CX,CY,CZ) and radius R)
- and then from this post process deform geometry proceed to a new static analysis.
Note that this is different from only an UPGEOM or UPCOORD command since I need to post process my deform geometry.
