RISA-3D Wall Panel Meshing Error
I have been modeling a 1-story special reinforced masonry shear wall building using RISA-3D version 8.1.3. I have two masonry walls that meet end to end and whenever the model is loaded and solved, I receive the following error.
"Mesher: abnormal intersection detected between wall panels WP31A and WP28B"
The model works fine when either one of these walls is not included in the model, so I can't figure out why when both these walls are included the model seems to crash. Does anyone have any suggestions. I've tried deleting them and re-inputting them several times with no success. Thanks!
-Seth
-Seth
RE: RISA-3D Wall Panel Meshing Error
Try that and run your model again. Should fix it.
