Cover on Nelson Studs
Do the same cover requirements (fire/corrosion) that apply to rebar also apply to headed welded studs (Nelson studs)? Should this cover be applied to the shank of the stud or the outside edge of the head of the stud?
I've been assuming that the same cover is required for studs as for rebar and that the cover is to the edge of the stud head. I would like to know what others assume however.
KK
KK
RE: Cover on Nelson Studs
BA
