Corrosion resistance of anodized aluminum AFTER engraving
There are 2 major engraving processes: rotary diamond bit and laser etch.  The rotary method is usually filled with a protective ink.  The laser method just burns the coating, not deep enought to fill.  What is the better method for longest life with outdoor exposures?  The material is hard anodized (black) aluminum...
