What to do if pipe weld joint is seating on pipe support?
In a large bore steel pipe,a pipe longitudinal and circumferential weld joint is seating on pipe support(saddle type). Could anyone help me to deal with this problem?Thanks
RE: What to do if pipe weld joint is seating on pipe support?
"In a large bore steel pipe" = What do you mean by "Large Bore"? What size (Nominal pipe size and Schedule) are you talking about?
"a pipe longitudinal and circumferential weld joint" = Do you mean both? Are you using ERW pipe? and Do you mean that a circumferential weld in ERW pipe has landed on this support?
"is seating on pipe support(saddle type)" = What is a "Saddle" type support? Are you actually meaning a "Cradle" support?.
