pipeline PWHT
pipeline PWHT
pipeline PWHT
On a typical pipeline automatic welding spread how soon after the last weld run (fill and cap pass)can/does PWHT take place i.e. how many joints after and typically how long would PWHT process be for heavy wall pipe around 10"?
RE: pipeline PWHT
I don't know.  I thought nobody could afford to do work at pipeline scales using a wall thickness high enough to require PWHT.
"We have a leadership style that is too directive and doesn't listen sufficiently well. The top of the organisation doesn't listen sufficiently to what the bottom is saying."  Tony Hayward CEO BP
"Being GREEN isn't easy." Kermitfrog http://www.youtube.com/watch?v=hpiIWMWWVco
http://virtualpipeline.spaces.liv
