large diameter chamber seal
I'm tasked with designing a large diameter seal for a chamber that needs to be opened quickly by operators.
I've been looking at designs like those on autoclaves (the red round design):
htt p://www.fu ngiequipme nt.com/aut oclaves/au toclaves/i ndex.shtml
I think this style works best, does anyone else have any other ideas?
Pressure is 60 psi, diameter is about 27inches.
I'm assuming that i can put a small taper on each of the teeth to help form compression. I'd appreciate it if you can give me any tips regarding the design of this.
Thanks!
htt
Thanks!
RE: large diameter chamber seal
