calculate castor force?
Is there a way to calculate or predict the self-centering effect of castor?  My vehicle in question is a bus, castor is set at 2.7 degrees, wheel/tire weighs roughly 250 lbs and tire OD is 42".  I am wondering what the scale of self-centering force is, and how one would describe it?
thanks, Brian
RE: calculate castor force?
Yes there is, but you need to know a lot more than the numbers you gave.
Basically figure out all the forces at the contact patch, and where they are applied, and then resolve those forces into a torque around the steering axis.
Cheers
Greg Locock
New here? Try reading these, they might help FAQ731-376: Eng-Tips.com Forum Policies  http://eng-tips.com/market.cfm?
