Mathcad 2d-image to 3d extrusion graph
I saw on the internet a webpage explaining how to extrude every single pixel of a 2d image according to their luminance/chrominance value.
The result is a 3D image with various levels.
Does someone know how to find such a link?
Or does someone have an idea on how to do that?
Thanks in advance
Thanks in advance
RE: Mathcad 2d-image to 3d extrusion graph
With the Image Processing extension pack:
1. Copy and paste your image into a worksheet.
2. Right click on the image to edit its properties, and check the option for "Output Selected Matrix" - this allows you to assign a variable name to the image array (matrix), which you can then manipulate as for any other array.
3. Create a Surface Plot of your array, and format as you wish (colour contours, line contours, etc).
Please see attached - hope I haven't infringed on Eng-Tips copyright in using their logo as the example image!
I knew mathcad and aero do not go along well but... how to tell mathcad "I installed the pack, use it!"?
Have you opened any of the examples that came with the Extension Pack, to make sure they work properly?
Otherwise, you might need to contact PTC for support. (In which case - Good Luck!)
