How to remove copper from carbon steel substrate?
What is the best solution (acid or otherwise) to remove copper deposits a mild steel without affecting the substrate underneath?
RE: How to remove copper from carbon steel substrate?
One possibility might be to use a nitric acid solution sufficiently strong to passivate the iron but attack the copper.
Other possibilities:
hydrocyanic acid (ugh!)
hot isopropyl acid
metallic mercury (probably your best bet).
Tim
Etch blast the surface with fine garnet you can remove the copper as well as polish the surface.
