How does PMG reduce EMI/RFI?
A client of ours wants to specify a PMG on a ~55kW genset for the purposes of EMI reduction.  How does this work?
I'm aware of the major benefit to PMG excitation as a reduction in the variations due to motor starting voltage drop, line harmonics, etc.
I can see that some manufacturers list EMI reduction as a benefit to PMG excitation, but details are lacking.
Can anyone enlighten me please?
Thanks for your help.
RE: How does PMG reduce EMI/RFI?
That's a new on me on me also. I will be eagerly awaiting an explanation.
Bill
"Why not the best?"
Jimmy Carter
There is usually some HF commutation noise from the excitation system rectifier which can be detected at the main terminals of a bus-fed exciter. A PMG isolates the excitation system from the main output. I can't think of any normal generator application where this would be a problem except maybe broadcast or telecoms, and even then it would be unlikely.
Thanks Scotty.
Yours
Bill
Bill
"Why not the best?"
Jimmy Carter
Many thanks.
Sounds like I'll have to figure out what they're really looking for, or afraid of.
