Wireframing certain objects in an assembly.
I'm using Solid Edge ST, and I don't know how to Wireframe a single object on an assembly.  For example, I want to wire frame the part that gaurds the rotor, but have my rotor in solid form.
RE: Wireframing certain objects in an assembly.
Not sure you can do it as such.
You can set a part to be a 'clear' or 'transparent' finish.  Then if you set the assy to be shaded with edges shown you'll kind of get the same effect - especially if you use white clear or something.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Ok, how do I set it to transparent finish, is that in the scene mode.
You can select the part, then on the view tab there is a style group. You should then be able to choose from one of the standard face styles - some of which are transparent.
Alternatively select the part, then on the view ribbon choose Format Faces. The the appearance tab has a setting for opacity.
Hope that helps
Jon Sutcliffe / Solid Mastermind
The Solid Edge Community. Video training sessions, best practice documents, process maps and interactive training http://www.SolidMastermind.com
I did it, thank you very much.
