Acad to PDF Plotting drops objects!!
First thanks in advance for any help you can give. My office has been finding that our pdf files generated by Acad occasionally have lines, notes, etc. "dropped". In other words when we generate a pdf file through Acad the resulting image will sometimes leave off notes or lines that are present in the drawing file.
I've upgraded to Acad 2011 and others in the office are using 2008, or 2009 but the problem crosses all platforms. We're also using different Adobe Pro versions, but the issue is the same regardless. It doesn't happen often, but it has eroded our confidence enough that we are hesitant to provide pdf files of drawings when the customers request them.
Has anyone else experienced this and if so were you able to resolve it?
RE: Acad to PDF Plotting drops objects!!
Jukin, we all have used the download, 'PDF995' for about 5 years, and liked it so well that we paid for a site license!
Rocky
Cheers . . . Rocky
Civil Development Group, LLC
Los Angeles Civil Engineering specializing in Hillside Grading
http://www.civildevelopmentgroup.com
http://www.civildevelopmentgroup.com/blog
