Dust explosion of grinded sulphur
Hi folks,
i'm in need of some advice:
a customer of our's is having troubles with his big-bag station. He fills 700-800 kg of grinded sulphur from a 1000 kg big bag to another big bag.
Again and again dust explosions occur.
Source is the friction of the material itself, not material-wall friction.
The system is not closed (sadly). Grounding did not work.
What are possible solutions to this problem ?
We are thinking atm:
reducing falling height of one bigbag to the other
closing the system
inertisation (nitrogen ?)
ventilation
best wishes
Alex.
RE: Dust explosion of grinded sulphur
Here's a few links to the CSB.org (Chemical Safety Board) of several completed investigations on actual dust explosions and fires:
West Pharmaceutical Services Dust Explosion and Fire, Location: Kinston, NC, January 29, 2003 - http://www.csb.gov/investigations/detail.aspx?SID=36&Type=2&pg=1&F_All=y
CTA Acoustics Dust Explosion and Fire, Location: Corbin, KY, February 20, 2003 - http://www.csb.gov/investigations/detail.aspx?SID=35&Type=2&pg=1&F_AccidentTypeId=1
Hayes Lemmerz Dust Explosions and Fire, Location: Huntington, IN, October 29, 2003 - http://www.csb.gov/investigations/detail.aspx?SID=33&Type=2&pg=1&F_All=y
Combustible Dust Hazard Investigation, Location: Washington, DC, October 01, 2004 - http://www.csb.gov/investigations/detail.aspx?SID=24&Type=2&pg=1&F_All=y
Imperial Sugar Company Dust Explosion and Fire, Location: Port Wentworth, GA, February 07, 2008 - http://www.csb.gov/investigations/detail.aspx?SID=6&Type=2&pg=1&F_All=y
Hi folks,
thank you very much for the much appreciated information. After i worked it through, i'll probably get back to you,
since then
Alex.
